Steering mod needed with ORA 4" lift
- jimnydms
05 Sep 2012 19:30 #47578
by jimnydms
Replied by jimnydms on topic Steering mod needed with ORA 4" lift
Hi rob thanks for clarifying that. Whilst your there the rough country shocks only come with 1 sleeve for the bushes with washers I presume they go on the bottom mounting point of the shock as that's where it pivots if you can just clarify that?
Cheers
Cheers
- Dave c
05 Sep 2012 21:00 #47599
by Dave c
Replied by Dave c on topic Steering mod needed with ORA 4" lift
If thats the case then why do they sell longer drop pitman arms ?????
- TomDK
05 Sep 2012 21:08 #47601
by TomDK
Replied by TomDK on topic Steering mod needed with ORA 4" lift
I guess for the same reason that you can also get panhard relocation brackets. Gives you better handling when panhard rod/steering rod is level. But they're not a must-have.
- g187eev
05 Sep 2012 21:21 #47606
by g187eev
Replied by g187eev on topic Steering mod needed with ORA 4" lift
All of the bushes shoild have steek sleeves in them apart from the top of the front shocks obviously...
These get assembled with the correct sleeves to our spec by the importer before they get to us... so if ur missing any just let us know on an email and we'll vet them to send them to you directlu asap.
RB
RB
- Dave c
06 Sep 2012 16:20 #47631
by Dave c
My understanding was panhards and drag links are best level when the cars suspension is sat unloaded on level ground but im sure i will be told otherwise !!!!!! hence longer pitman arms hi steer kits and panhard relocation brackets.
Time to create page: 0.172 seconds
