How can i upgrade my exhast system?
  • MudSlutJames
27 Aug 2012 10:48 #46861 by MudSlutJames
How can i upgrade my exhast system? was created by MudSlutJames
Wondering what modifications i can do to make the old girl sound a bit better, got a standard exhaust at the moment.
was wondering about decatting? or removing back box? or even a straight through?
any help or ideas please?
  • reaper
27 Aug 2012 12:53 #46874 by reaper
Replied by reaper on topic How can i upgrade my exhast system?
De-cat pipe is a good start , stops you wreking it when off-roading to :-) just pop it back on for mot .
KnN panel filter will sort out the suck and an after market backbox takes care of the blow
I have a snorkle KnN and a homemade bike backbox and its sounds awsome and gets off the line much better even with the girders for bumpers winch and rollcage big wheels etc etc
  • MudSlutJames
04 Sep 2012 23:01 #47502 by MudSlutJames
Replied by MudSlutJames on topic How can i upgrade my exhast system?
Sweet, il guessed il have to put the cat back on for the mot but thats not a problem i have just a straight pipe on with the same fixing ends as the cat so its just a simple case of undo the bolts and bolt the other bit in place. does sound a lot better now.
and nice bet yours sounds good thanks for your help :)
  • markyp2000
05 Sep 2012 17:32 #47562 by markyp2000
Replied by markyp2000 on topic How can i upgrade my exhast system?
get an old scrap cat knock the guts out of it and fit that as long as it look like a cat it will pass an mot on that part BUT many suzukis dont go trought a cat emissions test and thay are not printed in the mot test centers emmisions batabase book so thay have to put it trough a none cat test with the reading of CO NO HIGHT THAN 3.5% HC NO HIGHER THAM 2000 PPM AND THE LAMBDA IS NO TESTED so as long as it looks like a cat is fitted then thay should pass it but you may have to tell them about looking it up in the book as a lot of testers are not awere of this
Time to create page: 0.141 seconds
