King pin shims
  • Hastiekid
27 Aug 2012 06:49 #46839 by Hastiekid
Replied by Hastiekid on topic King pin shims
markyp2000 wrote: yer take the wheel off undo 4 bolts pop out king pin put shim in and replace all that was removed
Yep, Shimmed my kingpins the other week just like this, very easy job.
  • Jimnyash
27 Aug 2012 11:11 #46863 by Jimnyash
Replied by Jimnyash on topic King pin shims
markyp2000 wrote: iv never put shims in mine but where do thay go top or bottom
I did top only.
  • reaper
27 Aug 2012 14:01 #46885 by reaper
Replied by reaper on topic King pin shims
facade wrote: The jimny doesn't normally need shims: the machining was done well enough that the bearings preload within tolerances when you just bolt the kingpins into new bearing.
From what i have been told , heard from quite a few people and experienced first hand is this is not the case with the 2003 02 soft tops
They were machined wrong in the first place and rather than replace suzuki saw fit to fit shims , these didnt last long and resulted in death wobble
Easily cured by new shims but suzuki would never admit as this would mean a recall .
I did it on our old 02 and they only lasted a few thousand miles .. got fed up and traded it in
27 Aug 2012 14:21 #46887 by facade
Replied by facade on topic King pin shims
Ah: made in Spain! (Mine is Japanese built)
If they don't least long it sounds as though there is too much preload, and the shims needed to be between the flange and the hub (= 4 holes).
Best to split the steering knuckle, remove the big dust seal, and see how free the hubs are, Landrovers need a pull of about 3lb at the steering arm hole to keep them moving, I'd aim for this as a maximum.
  • madg21
27 Aug 2012 15:35 #46896 by madg21
Replied by madg21 on topic King pin shims
facade wrote: Ah: made in Spain! (Mine is Japanese built)
The 3lbs pull force max also works for me.
I have the death wobble even using the standard rim/wheel size and even after I replaced the kingpin bearings. The solution for me was the shim kit (not the Cu washers) from BigJimny shop and set my preload to 1kgf. I have been using my Jimny for a month now without problem. Thanks to BigJimny!
