Wipers advice please .
  • Gromit
17 Aug 2012 16:04 #46317 by Gromit
Wipers advice please . was created by Gromit
Hi guys, need some advice about the wipers please.
They don't work on intermitent or normal setting, they only work on the fast setting and don't go to the park position when turned off .
Is it the motor or the switch that has gone ???
  • markyp2000
17 Aug 2012 17:00 #46320 by markyp2000
Replied by markyp2000 on topic Re: Wipers advice please .
test the wiring at the motor you should have 1 earth 1 ignition live feed 1 intermitant live when switched to intermitant and a live when switching from speed 1 to 2 if you have all of this its probs the motor or a relay
  • Gromit
17 Aug 2012 17:46 #46322 by Gromit
Replied by Gromit on topic Re: Wipers advice please .
markyp2000 wrote: test the wiring at the motor you should have 1 earth 1 ignition live feed 1 intermitant live when switched to intermitant and a live when switching from speed 1 to 2 if you have all of this its probs the motor or a relay
Cheers mate, it was a broken wire at the motor, god knows how that has happened :S
Time to create page: 0.332 seconds
