Confirming the 4wd is working
13 Sep 2010 20:22 #4634
by kirkynut
Replied by kirkynut on topic Re:Confirming the 4wd is working
I would just go to manual freewheeling hubs or fixed hubs using one of Martin's spacers rather than chase after the problem.
I had a solid green light but no front wheel drive and just did away with the vacuum hubs, they are too much trouble!
- JimBru
14 Sep 2010 13:31 #4649
by JimBru
Replied by JimBru on topic Re:Confirming the 4wd is working
Cheers, I have downloaded the link so will work through that, if I get no where i will swap to manual hubs.
Cheers for your input
Mark
Mark
14 Sep 2010 14:38 #4653
by facade
Replied by facade on topic Re:Confirming the 4wd is working
I was thinking that it should be possible to modify the vacuum hubs to manual, just needs a button on the outside to knock in to lock, and pull out to unlock, the magnets hold everything in place.
- JimBru
15 Sep 2010 16:21 #4670
by JimBru
that write up is very good, thanks to who ever took the time out to create it. I haven't had a chance to look at the Jimny yet but at least I know where to look now
- Johnniehec
- Thank you received: 56
16 Sep 2010 11:27 #4674
by Johnniehec
Replied by Johnniehec on topic Re:Confirming the 4wd is working
Yes I agree this is an excellent guide, I thought I knew how the hubs worked but I had no idea about the vacuum tank and thought they only worked with the enging running.
The only query I have is with the "checking the system" guide 16.
Item c and e if the wheel turns then you can only say that either one or both of the hubs have not locked you can't say which one. At that point repeating fot the other wheel is pointless. If it's the one that's off the ground then obviously the wheel will turn, But that hub could be locked OK, the halfshaft would turn and counter rotate the other halfshaft in the diff if the other hub has not locked. Admittedly in the second case rotating the wheel might have more resistance but it might be difficult to tell.
Please feel free to point out the error of my ways if you think I'm wrong! :blush:
All in all I think this system is far superior to the many varieties of "automatic" FWH over the years, Frontera and Maverick spring to mind! and I think if mine failed I'd be tempted to fix them rather than replace them and this guide would certainly help.
16 Sep 2010 11:41 #4675
Replied by mlines on topic Re:Confirming the 4wd is working
Johnniehec,
It is quite possible that the guides are wrong as I am just a happy amateur. I have used this technique and believe it works because, with the Transfer Box in 4WD then the front wheels are locked to the back and therefore the front propshaft will not rotate. With the propshaft locked is it possible to easily use one front wheel to rotate the other halfshaft? If it is then I just got lucky with mine when I did it and tested the "broken" side first.
Time to create page: 0.257 seconds
