things just go from bad to worse
- markyp2000
13 Aug 2012 19:59 #46126
by markyp2000
things just go from bad to worse was created by markyp2000
i was carrying out a simple engine rebuild and
when head was removed found valve guides worn out
then noticed no1 piston sitting low
removed sump and then piston found conrod bent
soursed second hand rod
went to fit new rings and thay didnt fit
went to fit new bigend bearing guess what thay didnt fit
my question to you is has any one rebuilt a g13bb engine with patten parts if so where did you get them from and what was the make
- Dave c
13 Aug 2012 20:07 #46127
by Dave c
Replied by Dave c on topic Re: things just go from bad to worse
Where are you based mate ?
- markyp2000
13 Aug 2012 20:10 - 14 Aug 2012 17:32 #46129
by markyp2000
Replied by markyp2000 on topic Re: things just go from bad to worse
im in kent
Last edit: 14 Aug 2012 17:32 by markyp2000.
- markyp2000
14 Aug 2012 17:33 #46175
by markyp2000
update sent the head away to have the valve guides replace and guess what the head looks like it cracked
so waiting on a pressure test to be done if it ok
if not it will need welding wish i hadnt bothered now but at least when its dont i no its dont correctly also in having to have the new conrod ballanced along with the other 3 so it sould run smother
i may even get him to pollish and port the head and fitt bigger injectors
Time to create page: 0.234 seconds
