Jimny valve clearances.
- bazzab
11 Aug 2012 20:02 #45934
by bazzab
Jimny valve clearances. was created by bazzab
Hi all,
Did head gasket today phew what a job.
All ok apart from got a noisey valve. Did adjust them but in manual i have it said line crank pully notch up with 0 marking on timing cover. Only problem is my crank pully dosent have a notch in it!!
Anyone got any tips for getting it all set up ok for adjusting the bad boys?
Many thanks in advance.
Bazza.
Bazza.
- markyp2000
11 Aug 2012 20:10 #45935
by markyp2000
Replied by markyp2000 on topic Re: Jimny valve clearances.
if it dont have a notch how did you set the valve timing
- markyp2000
11 Aug 2012 20:14 #45936
by markyp2000
get number 1 cylinder inlet and exhaust valves rocking and adjust cylinder 4
cyl 2 rocking do 3
cyl 3 rocking do 2
cyl 4 rocking do 1
inlet 0.17mm to 0.21 mm
exhaust 0.27mm to 0.31 mm
and thay are adjusted when hot
cyl 2 rocking do 3
cyl 3 rocking do 2
cyl 4 rocking do 1
- bazzab
11 Aug 2012 20:20 #45940
by bazzab
Replied by bazzab on topic Re: Re: Jimny valve clearances.
Used the dent in the bottom cam belt pulley as opposed to ancillary belt pulley. As stated in manual.markyp2000 wrote: if it dont have a notch how did you set the valve timing
- bazzab
11 Aug 2012 20:21 #45941
by bazzab
You sir are a true gent. I really appreciate that. Again your advice is blooming bang on.
King regards.
Bazza.
markyp2000 wrote: get number 1 cylinder inlet and exhaust valves rocking and adjust cylinder 4
cyl 2 rocking do 3
cyl 3 rocking do 2
cyl 4 rocking do 1
King regards.
Bazza.
- markyp2000
11 Aug 2012 20:37 - 11 Aug 2012 20:42 #45942
by markyp2000
Replied by markyp2000 on topic Re: Re: Jimny valve clearances.
the dent in the cam pully should be pointing to 12oclock on the bottom
im doing a full rebuild on mine and found one of the conrods bent and the valve guides shot as well i was hoping to get mine all done this weekend but no thing always go wrong on my own cars
Last edit: 11 Aug 2012 20:42 by markyp2000.
Time to create page: 0.186 seconds
