Do we really need winche's that powerful?
02 Aug 2012 15:36 #45366
Replied by mlines on topic Re: Do we really need winche's that powerful?
Remember you can always double up the line in order to double the pulling "power" of a winch.
- JimnyX19
02 Aug 2012 15:40 #45367
by JimnyX19
Replied by JimnyX19 on topic Re: Do we really need winche's that powerful?
Right im going to sound think as anything by here now and it's off the subject to winches but what is a rock lobster gav? I've seen it a few times know poppin up on forum but don't know what it is , cheers nathan
02 Aug 2012 16:37 #45374
by facade
Replied by facade on topic Re: Do we really need winche's that powerful?
A rocklobster is a hybrid transfer box with a gearset made from two different 'boxes that gives very low ratios, ideal for fitting larger tyres and crawling over rocks, hence the name.
- Paul4x4
02 Aug 2012 16:51 #45377
by Paul4x4
Replied by Paul4x4 on topic Re: Do we really need winche's that powerful?
And what many people don't know, is that there are also gear sets with much lower ratios available for Samurai and SJ(only those with 4x4 light switch, mainly SJ413/samurai but also found in some later years 410's too) transfer boxes. Those are a bit more expensive, but also they are much better if you need LOW crawler gears and less noisy transfer box(those welded rocklobster gears make a lot of noise).facade wrote: A rocklobster is a hybrid transfer box with a gearset made from two different 'boxes that gives very low ratios, ideal for fitting larger tyres and crawling over rocks, hence the name.
- JimnyX19
03 Aug 2012 10:42 #45414
by JimnyX19
So you all think 10000lb is plenty ? Only so I know when I get one see, I'll be having a friend to make me a custom winch bumper shortly after I've done my lift, so I'll get winch first for measurements cheers nathan
- JimnyX19
03 Aug 2012 10:44 #45415
by JimnyX19
Cheers for info on rock lobster facade and paul
Time to create page: 0.211 seconds
