Rear Pan Hard Rod
  • chimpbikes
27 Jul 2012 15:39 #44997 by chimpbikes
Rear Pan Hard Rod was created by chimpbikes
Just a quick question.
If you remove the standard rear panhard rod from a jimny thats been raised 3" will you see the axle shift to centre and if so how much.
Tae.
  • Paul4x4
27 Jul 2012 16:44 #44998 by Paul4x4
Replied by Paul4x4 on topic Re: Rear Pan Hard Rod
No, it won't center by itself if you remove the rod. Might move some to random direction, but won't return to center. Why you wanna know that? Bolt some adjustable panhards under there, and measure the space between rim and chassis rail from both sides to center the axle.
  • chimpbikes
28 Jul 2012 08:58 #45010 by chimpbikes
Replied by chimpbikes on topic Re: Rear Pan Hard Rod
Hi Paul,
I bought it raised 3" but the castor or pan hard mods have not been done, so I'm looking into putting all this right.
I didnt know what to expect if I removed the P/H Rod.
So basically you should have the same distance both side's from wheel rim to chassis rail, front and rear
KAP seem to do a decent looking set of Rods.
  • markyp2000
28 Jul 2012 18:43 #45025 by markyp2000
Replied by markyp2000 on topic Re: Rear Pan Hard Rod
the distance should be the same left and right at the rear from chassis to wheel rim but the fromt may be a different distance as long as it the same both sides is should run true
  • chimpbikes
28 Jul 2012 19:08 #45028 by chimpbikes
I have got 1/2 inch to 3/4 of an inch difference between wheel rim and chassis rails, front and rear,,,,,,,,,looks like I need some adjustable P/H Rods.
Thanks for the info marky
Time to create page: 0.080 seconds
