Gearbox oil
- jayuk022002
24 Jul 2012 08:00 - 24 Jul 2012 08:01 #44798
by jayuk022002
Gearbox oil was created by jayuk022002
Last edit: 24 Jul 2012 08:01 by jayuk022002.
24 Jul 2012 16:54 #44815
by kirkynut
Replied by kirkynut on topic Re: Gearbox oil
I wouldn't get hung up on the brand but just had a quick look at my manual and it says 75w90 GL4.
So I would just get whatever your local motor factor has in that. Just make sure it's GL4 as there are additives in GL5 that eat away at some parts in the transmission.
GL5 is fine in the diffs though.
- markyp2000
24 Jul 2012 17:25 - 24 Jul 2012 17:27 #44825
by markyp2000
Replied by markyp2000 on topic Re: Gearbox oil
never come across that before just use ep75/90
Last edit: 24 Jul 2012 17:27 by markyp2000.
24 Jul 2012 19:02 #44835
by kirkynut
That you may not have but it's the way it is. It's no effort to ask for the right one at the motor factors but it is an effort to get a 2nd hand gearbox because you didn't use the right gearbox oil.
markyp2000 wrote: never come across that before just use ep75/90
24 Jul 2012 21:13 #44858
by facade
Replied by facade on topic Re: Gearbox oil
I used the Comma SX75w90 GL4 semi synthetic oil.
The trick is getting it in, I bought a 500ml oil syringe from Machine Mart to do the job.
Do remove the filler bung first, in case it is stuck, also lets the oil drain out easier if air can get in faster.
Smear thread sealant on the drain plug threads before fitting or it will drip Stag/Heamatite will do if you haven't got the proper stuff.
The GL5 additives eat away at the bronze bushes, this used to be a problem, but I think the GL5 additives changed to prevent it. I stick to GL4 to be on the safe side.
- jayuk022002
25 Jul 2012 11:11 #44887
by jayuk022002
Replied by jayuk022002 on topic Re: Gearbox oil
Cheers for the help guys
Went to the garage and asked for 75w90 GL4
Wont be a problem getting it in as its gearbox not in the car yet.
Old gearbox syncrho has gone
Time to create page: 0.221 seconds
