rear wheel bearing
  • kyrris
23 Jul 2012 17:40 #44758 by kyrris
rear wheel bearing was created by kyrris
Hello, does anyone know which is the best wheel bearing? is it skf ?
Also my car has abs but i have disconnect it, will the wheel bearing kit for the non-abs model fit my car ?
Thanks for any answers.
  • markyp2000
23 Jul 2012 18:18 #44766 by markyp2000
Replied by markyp2000 on topic Re: rear wheel bearing
is the car a off roader or a daily drive cos it wont pass an mot with the abs disconected even if the light dont work if theres an abs pump and no light its a failure i think the only differance is the abs ring
  • kyrris
24 Jul 2012 11:27 #44803 by kyrris
Replied by kyrris on topic Re: rear wheel bearing
The mot is not a problem. Thanks for the help
24 Jul 2012 16:43 #44813 by kirkynut
Replied by kirkynut on topic Re: rear wheel bearing
Timken are the best but Koyo from The Big Jimny Shop are still good and possibly the cheapest place to get them - they are what Suzuki put on originally and what a Dealer would sell but for alot more!!!
27 Jun 2019 09:41 - 27 Jun 2019 09:48 #210350 by Matt H-E
Replied by Matt H-E on topic rear wheel bearing
I'd advise anyone reading this to learn from my bitter experience - pay the money and get the Koyo's from wherever you can (I don't know about Timken bearings so can't comment on them). Preferably buy the Koyo's from Martin, or any other source if you have to, but be very wary of 'European manufactured' aftermarket bearings.
Here's why - Martin was out of stock so I bought what I thought was a good non-Koyo alternative. It turns out that these alternative bearings have a very sharp edge between bearing body and bearing cap (if that's what it's called), and don't have the slight chamfer that the Koyo's have (which allows smooth fitting). As a result the sharp edge on the alternative bearings bit into the bearing housing in the axle, and stuck refusing to go any further as they were now skew (even if by a micro-millimetre, but it's enough).
Only option - pull it apart again, cut off and throw away £££' worth of useless new bearings, buy the proper ones and start again.
The first photo is of the sharp edge on the not good bearing before I cut it off, the second photo is of a section of the original Koyo bearing - you can just see the all important chamfer.
Last edit: 27 Jun 2019 09:48 by Matt H-E.
27 Jun 2019 09:50 #210351 by yakuza
Replied by yakuza on topic rear wheel bearing
SKF, FAG, KOYO has little or none quality difference for our car-use.
At my work (gearbox manufacturing) there is no alternative to SKF due to cost/quality, but if customer use FAG after service we would not hold it against them i guess. Any other brands or copies would void warranty.
Most of our bearings are between 150-300mm in diameter so not directly comparable to rear bearings in a suzuki :)
NTN also is ok for smaller aplications.
Time to create page: 0.186 seconds
