Where do the vaccum pipes break?
- Coletti
17 Jul 2012 18:28 #44381
by Coletti
Where do the vaccum pipes break? was created by Coletti
Hey guys, my hubs no longer lock in and the 4wd light is flashing so im guessing one of the vaccum pipes has split, I was wondering if there was a usuall place it splits and that's all that needs replacing or do I have to replace the whole line?
Cheers
George
Cheers
George
- rooster
17 Jul 2012 21:39 #44431
by rooster
Replied by rooster on topic Re: Where do the vaccum pipes break?
Hi . I had the same . It is probably the front axle pipes. Two steel pipes running along axle rotten causing the air to escape . Mega expensive from suzuki so I used rubber vacuum hose and some plastic inserts to join it all together . Never had a problem since.
- Laminak
17 Jul 2012 21:46 #44433
by Laminak
Replied by Laminak on topic Re: Where do the vaccum pipes break?
Do you remind the dimension of yoour rubber vacuum hose ?
Thanks
Thanks
