Exhaust
- grumpy22
19 Jul 2012 20:40 #44561
by grumpy22
Replied by grumpy22 on topic Re: Exhaust
Well an hour in and very little progress. 1 down pipe to manifold bolt off, one seized, both cat to mid section bolts free but very tight. And mid section to back box bolts stuck and heads rounding! That's after 3 days soaking with plus gas!
The joys of DIY
The joys of DIY
19 Jul 2012 21:42 - 19 Jul 2012 21:54 #44566
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: Exhaust
Always undo the bolts when the exhaust is still hot it makes them easier to undo :dry: so wear cloves :whistle: .
2002 JLX Soft Top
Last edit: 19 Jul 2012 21:54 by dirtydogz.
- grumpy22
19 Jul 2012 22:15 #44568
by grumpy22
That's my next plan for tomorrow. Hope it stays dry!
- adamatdraycott
20 Jul 2012 07:12 #44579
by adamatdraycott
Replied by adamatdraycott on topic Re: Exhaust
My back box is a very near future job!
My mid section to rear nuts are very crumbled... how would i go about removing these?
The standard back box from suzuki has bolts welded through the flange... so nothing to turn on the other side.
Also, how do you free the box off the hangers? and is it worth new rubbers?
20 Jul 2012 19:23 #44610
by mcjimny
The new system should come with all new rubbers and bolts, mine did. Therefore just chop it all off, rubbers included! Always use new rubbers for piece of mind if nothing else they're peanuts to replace if you don't get them with the system.
Replied by mcjimny on topic Re: Exhaust
adamatdraycott wrote: My back box is a very near future job!
- grumpy22
21 Jul 2012 11:36 #44664
by grumpy22
Front pipe off, running engine did the trick. Rear box bolts totally rusted, no flats on heads. Think I'll cut the rear box off and fix the rusty nuts and bolts on the bench!
The saga continues
The saga continues
Time to create page: 0.214 seconds
