2003 jimny jumping out of reverse
  • jayuk022002
15 Jul 2012 19:46 #44211 by jayuk022002
2003 jimny jumping out of reverse was created by jayuk022002
Hi new to the forum and need some help
We have a 2003 jimny 1.3 special with 56000 miles on the clock
Completly standard and not used off road
It has developed a problem with reverse gear
After selecting reverse gear you can drive the car back a metre and then it will jump out of reverse.
Every other gear is fine and no grinding noises at all. All gears are nice and quiet
It will select reverse nice and easy.
Can anyone help me diagnose this problem please
  • reaper
15 Jul 2012 21:04 #44232 by reaper
Replied by reaper on topic Re: 2003 jimny jumping out of reverse
Sounds like a worn gate in the syncro , but may be something more simple .
Lift up the rubber boot and and check for anything obvious like worn or bent parts also try get under the truck and check the gearbox mounts are all ok and nothing is caught under there
  • jayuk022002
16 Jul 2012 20:17 #44291 by jayuk022002
Replied by jayuk022002 on topic Re: 2003 jimny jumping out of reverse
cheers will have a look
Time to create page: 0.122 seconds
