milage to replace the engine timing chain?
  • Knifeman
26 Aug 2010 07:58 #4405 by Knifeman
Hi, my 2003 Jimny has the DOHC engine witht he timing chain, not the belt. However the service manual I seem to have is the one with the older engine.
Two questions:
1. What is the typical milage to replace the timing chain
2. Is there a service manual with this new type of motor existing?
thanks guys
26 Aug 2010 08:09 #4406 by mlines
There is no recommended mileage to replace the chain. It is supposed to last the whole life of the engine.
There is a service manual for this engine, widely available on the Internet. Try a google for 99500-81A10-01E
26 Aug 2010 09:13 #4408 by facade
Provided you keep to regular oil changes with a quality oil, the chain will last the engine out.
(Pity the same can't be said for Vauxhall, my Corsa needs a new chain and tensioner after 30,000 miles :dry: )
BTW> don't "upgrade" to a Grand Vitara with the V6 engine: these eat chains and tensioners :ohmy:
31 Aug 2010 17:31 #4446 by kirkynut
How is the Jimny 1.3 chain tensioned anyone? I thought about mine recently as I watched it clock 60K and wondered about a tensioner. I've not had the opportunity to dig out my service CD.
31 Aug 2010 18:36 #4452 by facade
There is a shoe/plate that is pivoted at the top of the engine, and a tensioner (behind the waterpump) that pushes the other end of the plate towards the crank, and takes up any slack.
Suzuki are fairly good at this, I would stick to Golden Rules #1 and #2
#1 If it ain't broke: don't fix it.
#2 DON'T MESS.
Time to create page: 0.169 seconds
