Body lift spring spacers or longer springs?
- Thank you received: 252
19 Jun 2012 18:33 #42591
by j999pre
Grey pick up Jimny
Body lift spring spacers or longer springs? was created by j999pre
Just after some thoughts of what to do.
I've recently bought a rock lobster
My jimny has a 2" lift and 215 75 15 tyres at present.
I want to up the tyre size to 30 or 31.
Whats the best/most economic way of gaining the required height?
Cheers
Cheers
Grey pick up Jimny
- darthloachie
19 Jun 2012 20:10 #42605
by darthloachie
Replied by darthloachie on topic Re: Body lift spring spacers or longer springs?
cheapest is spring spacers and body lift (+ maybe caster correction bushes)
we've got 3" lift + spring spacers +massive arch trimming to get 31"s on
so 2"lift + 1 1/2" spring spacers and 2" body lift should do the same for a lot less money than a 4 1/2" spring lift
19 Jun 2012 21:31 - 20 Jun 2012 20:56 #42608
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Re: Body lift spring spacers or longer springs?
Cheers for that.
I'm torn between springs or a body lift I think. Kap do some 4" springs would my shocks be long enough?
Body lift sounds easiest though.
Decisions decisions
Its already got caster correction arms on.
Decisions decisions
Grey pick up Jimny
Last edit: 20 Jun 2012 20:56 by j999pre.
- zuki andy
19 Jun 2012 21:54 #42611
by zuki andy
Replied by zuki andy on topic Re: Body lift spring spacers or longer springs?
body lift is an easy job. and keeps your COG lower (ie its just the weight of the body gone up 2") if you lift another 2" on the springs the weight of the body, chassis, gearbox, everything apart from the axles goes up. plus when the spring is fully compressed it would still hit the arch.
- panosd
20 Jun 2012 06:16 #42616
by panosd
Replied by panosd on topic Re: Body lift spring spacers or longer springs?
The cheapest way is to fit a bodylift kit.
But its not the best solution. With b/l you get your mass center higher. So it will more possible to roll over.
The best thing is the lower hight with the biggest tire size you can.
Also the b/l doesn't provide you any longer travel of the axles.
In my opinion wait a little while, get some more money and go for a new suspension set up.
A new set of 3'' suspension lift with spring spacers of 1'', caster kit, panar brackets and brake lines wont
cost you more than 650 uk pounds.
A b/l kit will cost you about 150 uk pounds but it can't be compared with a full suspension set.
20 Jun 2012 20:59 #42671
by j999pre
Grey pick up Jimny
Hmm.
one post says bodylift to keep COG lower the other says spring lift for the same reason?
Ideally I'd like to add to my current set up of 2" spring lift and caster corrected arms.
I suppose I could sell the 2" get a 3" and then add the body lift. Widening the track to allow for the increase in Centre of gravity?
Grey pick up Jimny
Time to create page: 0.244 seconds
