Jimny lift and brake issues
  • AJ
18 Jun 2012 17:02 #42526 by AJ
Jimny lift and brake issues was created by AJ
Hi all! Have just gotten a jimny recently and totally new to it.
Have been reading around in the internet and forums and i plan to do a 4inch lift from ORA. Basically I'm buying whatever they are having for jimny. 1 question that i dont understand is, do i need a steering spacer if i do that lift kit? ORA told me absolutely nothing is needed as their kit will have everything...but i dont quite see the spacer inside.. also worry about prop spacer and whether i need it.
Do I need rear shock repositioner too?
As for the next problem i have, my carpet seems to be always wet no matter how many times i sun the car to dry it. I cant see any leaking from windscreen or other place.. the car floor carpet will be wet at the driver front back and passenger front back... i am getting very irritated because it stinks after a day.. :(
The other thing is when i drive and when i step on the brake while going over some uneven road or bumpy road, i can feel the brake pedal wobbling! Is this a normal thing or is this a problem?
Thanks in advance for any help! :)
  • AJ
18 Jun 2012 17:13 #42528 by AJ
Replied by AJ on topic Re: Jimny lift and brake issues
By the way, totally stock Jimny..hahaha.. cant wait for it to 'grow' up!
[IMG
18 Jun 2012 19:07 - 18 Jun 2012 19:11 #42534 by kirkynut
What do you mean by a steering spacer??? Do you mean a steering damper???
Do I need rear shock repositioner too? No
As for the next problem i have, my carpet seems to be always wet no matter how many times i sun the car to dry it. I cant see any leaking from windscreen or other place.. the car floor carpet will be wet at the driver front back and passenger front back... i am getting very irritated because it stinks after a day.. :( What do you mean by front back? - front and back are opposites - I understand the language problem
The other thing is when i drive and when i step on the brake while going over some uneven road or bumpy road, i can feel the brake pedal wobbling! Is this a normal thing or is this a problem? If only over uneven ground I would check the kingpin bearings and wheel bearings on the front, otherwise the discs or rotors are warped
Last edit: 18 Jun 2012 19:11 by kirkynut.
  • VAXXi
18 Jun 2012 19:21 - 18 Jun 2012 19:22 #42536 by VAXXi
Replied by VAXXi on topic Re: Jimny lift and brake issues
No, he means a steering spacer. Looks like this (from Jimnybits):
On a 2" BL the shaft is quite close to the end, I imagine a 4" would definitely require a spacer.
Last edit: 18 Jun 2012 19:22 by VAXXi.
  • AJ
18 Jun 2012 20:18 #42538 by AJ
Sorry if my english is bad :(
What i meant was the driver side carpet is alw kinda wet, so is the same for the driver side and the rear seat flooring carpet..
Initially i thought it was the wiper spray pipe thay runs underneath the carpet causing leak but i took the entire carpet out and the pipe only runs on the left side of the interior so i dont think it spreads to the driver side and the water level in the holder wasn't dropping fast to indicate a leak in the tubing.
As for the braking wobble on uneven road, i will jack the car later to try the wheel and see if it shakes.
Thanks for the help! Keep them coming if u suspect other cause for the wet carpet and wobbling brake on uneven road.
  • AJ
18 Jun 2012 20:21 #42539 by AJ
VAXXi wrote: No, he means a steering spacer. Looks like this (from Jimnybits):
This is what I'm referring to.. I'm not doing body lift, I'm only gonna do the 4" sus lift kit from ora and wondering if this steering spacer is needed.. ora mention it's not needed but I'm jus seeking a peace of mind and to save on having to ship twice..
Time to create page: 0.498 seconds
