1/2 shaft ball bearings
- craigh
12 Aug 2010 16:57 #4203
by craigh
1/2 shaft ball bearings was created by craigh
Hi all, just changed the knigpins on both sides of my 2001 jimny, my question is on the passenger side the ball bearings in the half shaft were held in place with a collar but on the drivers side when I pulled out the 1/2 shaft they ballbearings fell out, I put it back together and it seems the ball bearings are held in just by the shaft pulling against them. Is this normal or do I need a new 1/2 shaft for the drivers side? Thanks (sorry for the not so technical lingo!)
12 Aug 2010 17:09 #4204
Replied by mlines on topic Re:1/2 shaft ball bearings
Ummm - thats not good!
Sounds like the front wheel bearing has collapsed. You need a new front wheel bearing (unless its the CV joint you are talking about - in which case you need a new CV joint)
Can you describe the part a bit better or post a picture
- craigh
13 Aug 2010 13:15 #4216
by craigh
Replied by craigh on topic Re:1/2 shaft ball bearings
Thanks for your reply, I had a look at the how to guide and it is the cv joint that has gone, Ive only recently brought it and its not been looked after. when I changed the kingpins the old ones had been ripped apart in the nuckle so that exlains it. going to get a new wheelbearing in there when u have stock again, but my big question is does anyone have a cv joint for sale or know where I can but one? thanks
- craigh
13 Aug 2010 14:11 #4217
by craigh
(its for a g13bb engine)
Time to create page: 1.879 seconds
