My New Front Recovery Set-up
- goatboy
- Visitor
07 Jun 2012 12:00 - 07 Jun 2012 12:01 #41905
by goatboy
My New Front Recovery Set-up was created by goatboy
Over the long weekend I decided it was time to address my lack of recovery points.
Now I didn’t want a different bumper and I didn’t really want 2 big chunks of steel protruding from the bumper all the time so I set about making a removable system.
I bought some heavy duty lifting eyes off ebay SWL rated to 2.5t and with an M24 thread about 20cm long they are very heavy duty.
So I added some steel tube, some angle iron and some welding to come up with my now fitted system
First thing, take off the bumper. Surprisingly clean and rust free
I cut away half of the mount for the front bumper and put some slots in the body mounts to slide my angle iron through. Some very rather awkward welding directly to chassis legs and body mounts and everything is firmly in place
On the drivers side the chassis leg isn’t nice and flat like it is on the passenger side so there is less to weld to. I welded where I could and added a 16mm bolt drilled and tapped right through the angle iron and both sides if the chasis. I think the weld would have been sufficient on its own but I feel more comfortable with a big bolt in there as well.
Test fit of the lifting eyes
All looks good so a coat of zinc primer followed by lashings and lashings of under sealant.
Bumper back on, drill some holes for the eyes to go through and then screw them in.
Check the shackles fit on…
All good!
Next job, fit towbar on the rear…
All good!
Last edit: 07 Jun 2012 12:01 by goatboy.
- markyp2000
- Visitor
07 Jun 2012 12:48 #41908
by markyp2000
Replied by markyp2000 on topic Re: My New Front Recovery Set-up
nice job jusy one question did you weld the hole up on the chassis leg just above where you put the tube etc
- goatboy
- Visitor
07 Jun 2012 13:12 #41910
by goatboy
Replied by goatboy on topic Re: My New Front Recovery Set-up
- markyp2000
- Visitor
07 Jun 2012 16:57 #41919
by markyp2000
yer thats the bit
- goatboy
- Visitor
07 Jun 2012 18:08 #41925
by goatboy
No I didn't. Ther is a small weld on the bumper bracket. Why you ask?markyp2000 wrote: yer thats the bit
- markyp2000
- Visitor
07 Jun 2012 18:16 #41928
by markyp2000
strenth it may be a bit week but im shore you will be the first to no if it fails
Time to create page: 0.136 seconds
