Has anyone replaced oil seals on the transferbox ?
- pstrom
02 Jun 2012 17:46 #41640
by pstrom
Has anyone replaced oil seals on the transferbox ? was created by pstrom
After replacing my wheels i had a really bad "Death wobble" on my -04 Jimny that was caused by both worn kingpinbearings and a incorrect tirepressure (too high).
I found all info needed here at BigJimny and was able to replace bearings and the result is: no more wobble.
But all the "wobbling" that occured seemes to have shaken the transmission so bad that the seal on the incoming axle was damaged and is leaking.
Is it possible to replace the seal without having to completely remove and disassemble the box ? Is there anyone out there with info on how to do this?
Thanks!
Thanks!
- markyp2000
02 Jun 2012 18:29 #41646
by markyp2000
Replied by markyp2000 on topic Re: Has anyone replaced oil seals on the transferbox ?
take it all out and change all 3 seals as there is not much room in that area to work then you no it done right and you can see what your doing
- renard38
02 Jun 2012 18:40 #41649
by renard38
Replied by renard38 on topic Re: Has anyone replaced oil seals on the transferbox ?
Time to create page: 0.235 seconds
