"van panels" to replace side windows?
- P.Y.
09 Aug 2010 23:12 #4158
by P.Y.
"van panels" to replace side windows? was created by P.Y.
For the London to Cape Town World Cup Rallycar project: Is there anyone who does a panel that replaces the side-window glass...not so much a weight-saving thing here but just something that might add a touch more security.
The driver would prefer the "van look" as the reduced glass area might mean slightly cooler air inside! Any suggestions?
10 Aug 2010 06:53 #4161
Replied by mlines on topic Re:"van panels" to replace side windows?
I don't know of any "off the shelf" panels. I know KAP Suzuki sell Jimnys that have been converted to "VAN" and I suspect they have simply cut out a sheet of steel and welded it into the window opening.
- ooky_123
10 Aug 2010 08:50 #4164
by ooky_123
Replied by ooky_123 on topic Re:"van panels" to replace side windows?
What martin says really .... take out the glass and tac a bit of sheet metal to the opening.
- Adamski
15 Aug 2010 17:58 #4238
by Adamski
Replied by Adamski on topic Re:"van panels" to replace side windows?
Im going to be doing this to mine in a couple of weeks. Basically im going to get a sheet of adhesive vinyl (the type car decals are made out off) which I have matched to the colour of the car and cut it to the same shape as the windows and then stick it on. See a photoshop of how mine will look when I have fitted the vinyl on the rear windows:
Is this what you are hoping to achieve with yours?
- darthloachie
16 Aug 2010 10:11 #4249
by darthloachie
Replied by darthloachie on topic Re:"van panels" to replace side windows?
if you get one way vinyl you will still be able to see out through it
- Adamski
16 Aug 2010 17:16 #4255
by Adamski
darthloachie wrote:
The stuff im using is opaque so you wont be able to see in or out. If you did still want to see out im sure you could get some blue window tint material, but it would look less like a van because the colour would differ to the car body. I've spent ages with sample books trying to get my vinyl the same colour as the car and i've found the closest match.
Time to create page: 0.162 seconds
