Crunch when pulling away in first gear
  • Mala43B
02 Jun 2012 21:49 #41657 by Mala43B
Replied by Mala43B on topic Re: Crunch when pulling away in first gear
I get a machine gun type noise from time to time but always whilst driving along and in 2H. It usually starts if I hit a bump/pot hole in the road then the sound goes away as soon as I engage 4H or slow down.
Its only intermittent so I haven't bothered to try find the fault, but my first thought was one of the hubs does not fully unlock and maybe sliding towards, and trying to engage, the drive shaft splines. As the drive shaft is stationary when in 2H but starts to rotate when you put it into 4H this would enplane how I get the noise in 2H but not 4H.
Any thoughts?
13 Jun 2012 06:57 #42279 by robs5230
i have a similar noise and have and now also put it down to the hubs. dont think its the noise they have described with the chain though.
now bought manual hubs and hopefully this will be cured.
my noise is exactly as yours, brought on going over a bump and will go itself as i speed up. never get it on pulling away.
standard jimny - for now
24 Jun 2012 15:04 #42828 by robs5230
just to confirm , fitted manual hubs - no scraping noise any more. mine must have been the vac hubs not completely disengaging.
  • 247sniper
24 Jun 2012 19:38 #42838 by 247sniper
Replied by 247sniper on topic Re: Crunch when pulling away in first gear
robs5230 wrote: just to confirm , fitted manual hubs - no scraping noise any more. mine must have been the vac hubs not completely disengaging.
Did you check to see if the hub vac pipes were still connected or still intact?
Thanks for letting us know mate.
Steve.
24 Jun 2012 20:29 #42845 by robs5230
yeah all vac pipes in place. probably a build up of crud in the vac hub. all good now , 30 mile drive this afternoon on bumpy roads , no noises. happy days :)
