Retro Fitting an autobox on a '99 manual jimmy
- jimnydms
31 May 2012 21:11 #41528
by jimnydms
Retro Fitting an autobox on a '99 manual jimmy was created by jimnydms
Hi does anyone know if you can retro fit an autobox to a 99' manual jimmy is it a simple bolt off bolt on job or are there electrics involved, is the auto any better or the any worse for off roading?
Cheers I await your wise answers
31 May 2012 22:43 #41533
by facade
Replied by facade on topic Re: Retro Fitting an autobox on a '99 manual jimmy
They are electronically controlled, so you need more wiring harness and the controller, as well as the flywheel from the auto and the gear shifter. Easier to get an auto car rather than convert yours.
- rjd1
31 May 2012 23:28 #41534
by rjd1
Replied by rjd1 on topic Re: Retro Fitting an autobox on a '99 manual jimmy
keith on here has done it before need to adjust tunnel with B.F.H to fit
01 Jun 2012 16:31 #41585
by kirkynut
Replied by kirkynut on topic Re: Retro Fitting an autobox on a '99 manual jimmy
Rhinoray is the man in the know from the UK Zuk specialists but I agree it would be easier and more sensible to buy an auto and swap everything across if your Jimjam is modded. Then sell your now standard manual. If yours is not modded, just sell yours and buy an auto!
- jimnydms
02 Jun 2012 06:44 #41606
by jimnydms
Replied by jimnydms on topic Retro Fitting an autobox on a '99 manual jimmy
Ok appreciate all the advice, what does everyone think regarding a manual or auto box for off roading ?
02 Jun 2012 07:48 #41608
by kirkynut
That depends on what sort of offroading and how much you want to modify your truck and what size tyres you plan to fit.
If you are keeping it basic with smallish tyres, go auto but if you will get big tyres go manual and have a rocklobster transfer box to sort out the ratios.
Time to create page: 0.211 seconds
