exhaust blowing
- Johnniehec
- Thank you received: 56
01 Jun 2012 12:14 #41565
by Johnniehec
Replied by Johnniehec on topic Re: exhaust blowing
Mine went there as well,
Fairly easy to weld, it's double thickness.
John.
John.
- zaine
01 Jun 2012 13:27 #41569
by zaine
Replied by zaine on topic Re: exhaust blowing
also done this same repair on a jimny, 5mins with a welder, good as new
01 Jun 2012 16:36 #41586
by kirkynut
Replied by kirkynut on topic Re: exhaust blowing
If it's a single cam engine there is a gasket that fails regularly and is cheap enough and easy enough to replace. I think this is what you are describing. If so, I had this on my first Jimjam and I think Suzuki supplied a revised part that doesn't go as often.
- markyp2000
01 Jun 2012 17:44 #41592
by markyp2000
any thing before a k reg dont need a cat and any after does but seeing as im an mot tester no suzuki is in 17 editions book of exhaust emisions so that means it has different limits the other cars on the road and some times its just a basic emitions check ie co no more than 3% and hc no higher the 2000ppm and lambda doesnt come in to it
Replied by markyp2000 on topic Re: exhaust blowing
dirtydogz wrote: If it's not to bad, see if you can get some one the weld it back together, if not you will need to buy a new cat. :dry:
In the UK it's not legal to run a car without a cat on the road. :evil:
- ne-crock
01 Jun 2012 22:27 #41603
by ne-crock
Replied by ne-crock on topic Re: exhaust blowing
<object width="400" height="224" ><param name="allowfullscreen" value="true" /><param name="movie" value="
www.facebook.com/v/10151161232243747
theres a video of the sound, i really dont want to fix it
i completly forgot about a photo i'll sort one tomorrow, going to have to drive it to work and back over the weekend
- Tommo
01 Jun 2012 23:15 #41604
by Tommo
Replied by Tommo on topic Re: exhaust blowing
Time to create page: 0.217 seconds
