can the vacuum hubs be permanently locked ??
- Thank you received: 77
31 May 2012 19:15 #41508
by robs5230
standard jimny - for now
can the vacuum hubs be permanently locked ?? was created by robs5230
as vacuum operated hubs are so much of an issue and finding manual hubs so difficult does anyone know if the normal auto hubs can be physically locked by stripping and setting the collar in the lock position and disconnecting the vac pipes ??
not sure whether i read this on here or the trooper forum ( the trooper suffers exactly the same issues with the auto hubs ).
having permanently locked hubs will be no problem as it is not a daily driver.
thanks rob
thanks rob
- rjd1
- Visitor
31 May 2012 19:41 #41513
by rjd1
Replied by rjd1 on topic Re: can the vacuum hubs be permanently locked ??
take cover off them activate hub, finger, screwdriver it just slots in no bother
get short piece of tube with either a bolt in the end or just tie a knot in it and remove vac hose an fit short piece
some old sj`s ran with engaged hub`s with no drag or extra fatigue
done it to 2 previous jimny`s with no adverse problem`s
- myers647
- Visitor
31 May 2012 19:47 #41515
by myers647
Replied by myers647 on topic Re: can the vacuum hubs be permanently locked ??
Hi mate yes as already mentioned it can be done easily in 5 minutes.Last time we was out laning my mates vacuum hubs failed so he had to lock them manually and they stayed in.
31 May 2012 19:49 #41516
by robs5230
Replied by robs5230 on topic Re: can the vacuum hubs be permanently locked ??
this is sounding good. what do you do about the vac pipes from the car to the hubs ? and can the connections on the hub be joined with a short piece ?
- rjd1
- Visitor
31 May 2012 21:03 #41525
by rjd1
no need to touch them
small pipe comes from plenum chamber this is the vac hose pull it out cable tie to safe place
short piece o pipe either with knot or bolt in the end pop it on to plenum chamber activate hubs manually job done
31 May 2012 21:23 #41529
by robs5230
now i got it cheers
Time to create page: 0.148 seconds
