Can the Rear wheel stud be removed & replaced???
  • myers647
  • Visitor
  • Visitor
30 May 2012 21:28 #41469 by myers647
Hi how are the wheel studs removed and replaced.Can this be done???
Thanks
James
  • reaper
  • Visitor
  • Visitor
30 May 2012 21:41 #41470 by reaper
Have you bust one ?
Normally its just a case of adding some heat to the surrounding area and knocking it out through the back
Iv not done it on a jim but replacements are available so guessing you can :-)
  • blakey2000
  • Visitor
  • Visitor
30 May 2012 23:22 #41473 by blakey2000
if its much like replacing them on other cars just hit them from the front (where your wheels bolt on) out the back with a big hammer, newer cars they come out pretty easy with just a hammer, but id say older cars would require some heat on the plate they are attached to, to expand the holes to free them up.
  • markyp2000
  • Visitor
  • Visitor
31 May 2012 16:58 #41500 by markyp2000
just hit it hard a few times it will pop out then us some washers and a wheel nut to pull it back in again job done
Time to create page: 0.124 seconds
