cv joint????
  • Madge
28 May 2012 16:32 #41288 by Madge
cv joint???? was created by Madge
hi there i was off roading the other day an there was a loud crack from the front axle and ive lost 4wd it also clicks when turnin in 4wd is this the cv joint if so wat size do i need and are there one for each side at diffo sizes as i have a brand new one for a suzuki sj will it fit my jimny is a 2000 reg 1.3 thanks matt
  • vitara_mad
28 May 2012 19:04 #41302 by vitara_mad
Replied by vitara_mad on topic Re: cv joint????
not sure but i think sj cv's are differant & there is 2 differant cv's for jimny's you will need to remove your cv to check
theres is 1 cv on each shaft & they will be be same
Time to create page: 0.157 seconds
