Advice on repairing this
  • ianR
21 May 2012 19:35 #40871 by ianR
Advice on repairing this was created by ianR
After investigating a knocking noise i had, i was greeted by this:
Any advice on the best way to repair it, the other side is clean off too.
21 May 2012 19:46 #40872 by mcjimny
Looks like an axle strip down and weld on some new beefier jobs and some bracing. Is this not similar to martins problem?
21 May 2012 21:48 #40894 by kirkynut
It appears similar to Martin's problem and I believe from what Martin wrote in his blog that Rob Butler at Off Road Armoury had new brackets made up and has saved the CNC work on them to be able to get more made up.
I'd suggest a call to Rob Butler to see what he can do for you by way of sending you new brackets, then you need to get it to a good welder who can weld it on in the right place - maybe in a position that corrects castor if you need it.
  • ianR
25 May 2012 06:02 #41120 by ianR
Replied by ianR on topic Advice on repairing this
I've managed to order some from him, just got to wait a week for them now. Many thanks !
On stripping in down last night I noticed the drivers side drive shaft splines seem slightly twisted is this standard or more money I'm going to have to spend?
25 May 2012 19:22 #41158 by facade
Replied by facade on topic Re: Advice on repairing this
The shaft is twisted, replace it before it shears.
  • ianR
25 May 2012 19:32 #41159 by ianR
Replied by ianR on topic Re: Advice on repairing this
Oh well, least its all apart. :(
Cheers for confirming it.
Time to create page: 0.159 seconds
