SJ Manual Hubs
06 Aug 2010 06:06 - 06 Aug 2010 06:08 #4099 by mlines
Replied by mlines on topic Re:SJ Manual Hubs
I think the general advice is to install them in the "free" position. I think the manual mechanism places pressure on the spring to force the inner locking ring forward when in the locked position. It is then possible when fitting them "locked" to jam the locking ring if it is not smoothly fitted on the splines.
Fitting them in the "free" position allows the locking ring to float and find its own resting position more easily.
And, no, you cannot do up the inner bolts with the top cap fitted on some models of locking hub. Put the hub to "free" and remove the cap.
Last edit: 06 Aug 2010 06:08 by mlines.
06 Aug 2010 06:14 - 06 Aug 2010 17:05 #4100 by mlines
And a timely post on Difflock points you to here...
.. HERE
Last edit: 06 Aug 2010 17:05 by mlines.
  • ooky_123
06 Aug 2010 16:58 #4112 by ooky_123
Replied by ooky_123 on topic Re:SJ Manual Hubs
Page not found Martin
06 Aug 2010 17:05 #4113 by mlines
Thanks - Link now fixed
  • ooky_123
17 Aug 2010 09:57 #4267 by ooky_123
Followed the above doc and re-stripped them down last night. I think I know the problem ... I might have put too much or the wrong grease in them ... its stopping the locking part from locating on the splines.
Will remove this evening, de-grease and maybe put some graphite grease on it rather than traditional grease.
Could it be the spring also has weakened ?
17 Aug 2010 12:34 #4268 by Obarno
Replied by Obarno on topic Re:SJ Manual Hubs
To fit the hubs without taking them to pieces is easy if you have an Allen key with a ball on the bottom. This will then allow you to tighten them up as normal. I have a key from Snap On that is longer than the hubs are deep and has a 3/8" drive.
Time to create page: 0.262 seconds
