stiff clutch pedal
- vitara_mad
17 May 2012 20:03 #40557
by vitara_mad
Replied by vitara_mad on topic Re: stiff clutch pedal
had same problem on my jimny & it was the cable i think it was about £32 for a new 1 for local motor spares
- myers647
17 May 2012 20:08 #40558
by myers647
Replied by myers647 on topic Re: stiff clutch pedal
Thanks for the help thats what me and my brother thought it was because the clutch its self actually felt ok just the pedal was very stiff.
- Jansku991
26 Sep 2015 20:18 #152598
by Jansku991
Replied by Jansku991 on topic Re: stiff clutch pedal
Hello! Please, help.
I also as well have on my Jimny stiff clutch. Ex-owner has changed the clutch so it should be ok. It's also hard to put right rear, because the gearbox doesn't work easily.
When the clutch is warm, it's much easier change gears.
I have changed gearbox oils but it didn't helped.
What should I do? Try to adjust the clutch or something more?
Br, Jansku
Br, Jansku
27 Sep 2015 06:27 #152602
Replied by mlines on topic Re:stiff clutch pedal
Did he change the clutch cable as well? It is simple to change
www.bigjimny.com/store/genuine-suzuki-clutch-cable.html
Sent from my Nexus 5 using Tapatalk
- Jansku991
27 Sep 2015 08:16 #152603
by Jansku991
Replied by Jansku991 on topic Re:stiff clutch pedal
Actually I don't know.
It would help change the cable. But I don't belive that it's cable's fault that changing gears is stiffy.
For example rear gear and 1 st. gear.
Time to create page: 0.147 seconds
