jimny panhards
  • jamesey
25 Feb 2009 19:36 #403 by jamesey
jimny panhards was created by jamesey
which way round do they go , with the adjuster nut on the passender side or on the drivers side , also how do you know when they are set right and how do you do it , cheers
25 Feb 2009 20:05 #404 by kirkynut
Replied by kirkynut on topic Re:jimny panhards
Hold on whilst your still on line and I'll go and have a look ... was just about to reply to your other post aswell so stand by...
25 Feb 2009 20:09 #405 by kirkynut
Mine are mounted with the adjustable side on th drivers side both on the front and the back, however, I can't see why it should make a difference.
  • jamesey
26 Feb 2009 08:16 #408 by jamesey
Replied by jamesey on topic Re:jimny panhards
how do you adjust them or how would i know when to??:dry:
26 Feb 2009 08:49 - 26 Feb 2009 08:55 #409 by mlines
Replied by mlines on topic Re:jimny panhards
The panhard rod keeps the whole axle central underneath the car.
Therefore the key measurement/adjustment is to check the that wheels are central, ie one tyre does not stick out more on one side than the other one does the other side
Code:
Ok = OOOO |__| Wheels too much left = OOOO |__| Wheels too much right = OOOO |__|
So on a flat level surface see how your car sits and adjust the rod accordingly. Normally a car will sit pretty central without the rod on a level surface. So disconnect the rod and check and then adjust the rod so it bolts straight on without pulling the car left or right. This shoudl be a good starting point
Last edit: 26 Feb 2009 08:55 by mlines.
  • jamesey
26 Feb 2009 08:59 #410 by jamesey
its going to darren at kap next week ive had enough with it , di you see my other probs with it in my other thread
