2" lift. only one minor issue.
  • Tommo
  • Visitor
  • Visitor
10 May 2012 20:48 #39905 by Tommo
Replied by Tommo on topic Re: 2" lift. only one minor issue.
pipes connected or not connected, nothing abit of windcreen washer pipes cant sort out :pinch:
a friend of mine his fwd wasnt working, not because they wernt connected, a mouse had chewed the pipe some where along the line, he replaced it with the wiper hose, bobs your uncle fannys your aunt job done :woohoo:
10 May 2012 21:39 #39913 by Johnniehec
Yes definitely agree a hose must have become dislodged, check the rubber hoses between floor and radius arm and at both hubs, could easily have been dislodged when fitting springs.
John.
  • Sandez
  • Visitor
  • Visitor
10 May 2012 23:59 #39921 by Sandez
Replied by Sandez on topic Re: 2" lift. only one minor issue.
When you put it into 4wd can you hear the hubs locking (or unlocking)? If you can hear it, then as with my old one when I bought it, check the rubber hoses havent been knocked off and put back on crossed over (makes it lock in 2wd and unlock in 4wd), or it would be a hub issue.
If there is no noise then check the hoses for deterioration/too loose or it has something to do with the pump.
11 May 2012 00:08 #39923 by kirkynut
I would go mad if I still had auto freewheeling hubs and they played up - I went for manual ones the day I bought the JimJam having read all the posts like this and that was about 4 years ago - if I got a pound for every post like this I've read since I could buy another set of manual hubs!
Throw them at next door's cat when it next does it's business in your garden and invest in a set of manual hubs, then the light can do what it wants and you just twist the knobs to set them to free when you go back on the road for any length of time!
  • jakexme
  • Visitor
  • Visitor
21 May 2012 16:57 #40862 by jakexme
Replied by jakexme on topic Re: 2" lift. only one minor issue.
Problem solved. Some decent Nylon tubing. cable tyes and arrldite. onlt temporary until i either refurbish the entire vacume lines in 1/4" stainless. or by manual hubs
Cheers
Time to create page: 0.406 seconds
