the jimny lean ????
12 May 2012 16:52 #40077
by kirkynut
Cool cheers!
Replied by kirkynut on topic Re: the jimny lean ????
reaper wrote: Just one spacer one the front normally does the trick
Cool cheers!
- Thank you received: 77
12 May 2012 20:17 #40095
by robs5230
standard jimny - for now
Replied by robs5230 on topic Re: the jimny lean ????
hi guys, what size spring compressors do i need ??
cheers
cheers
12 May 2012 21:42 #40101
by kirkynut
There are different sizes?
I have a set of Laser Tools compressors that I have used to change the springs on my Jimjam. Getting them on opposing sides of the rear springs is tricky due to space.
robs5230 wrote: hi guys, what size spring compressors do i need ??
cheers
- supergaz
- Visitor
13 May 2012 09:16 #40110
by supergaz
Replied by supergaz on topic Re: the jimny lean ????
I get away without using my spring compressors, Just unbolt the shocks and jack it up high.
Just be careful not to strain the brake lines.
- Goat
- Visitor
13 May 2012 09:34 #40113
by Goat
Replied by Goat on topic Re: the jimny lean ????
It is odd that on the standard jimny the rear drivers spring is the longer. The front ones are the same length. Yet most people compensating for the lean adjust the front. Not saying this is wrong just point it out. Has anyone tried correcting with a spring spacer on the rear?
Time to create page: 0.160 seconds
