has any used one of these
- Sponnie
- Visitor
10 May 2012 20:03 #39887
by Sponnie
Replied by Sponnie on topic Re: has any used one of these
The lift wont matter by the looks of the design.
Yes you will have to paint it red!
Depending on which (mine is set on the lowest of the holes) position you decide to bolt the dampers back on, it could foul something. Currently my damper on full compression just tickles the exhaust for example. Nothing 10mins with a hammer wouldnt sort out.
- suzuki jimny fella
- Visitor
10 May 2012 20:45 #39903
by suzuki jimny fella
Replied by suzuki jimny fella on topic Re: has any used one of these
have you got any pics matey thanks
- bluejimny
- Visitor
10 May 2012 20:53 #39906
by bluejimny
Replied by bluejimny on topic Re: has any used one of these
12 May 2012 12:44 #40053
by kirkynut
Replied by kirkynut on topic Re: has any used one of these
We used to have one of these type of brackets on our old SJ but the springs on that were so blinking hard I couldn't tell what difference it made on the road and I have no idea what difference it made off road because I fitted it soon after we bought her.
ORA say: Adjust the angle of your rear shocks allowing you to change the travel, articulation and ride quality of your Jimny.
I think it may allow better articulation but I don't know how or why.
As for ride quality - If it stops it being so crashy over speed bumps it can only be a good thing as they drive me mad - but you can't slow down too much for them in a massively modified Jimny or you'll look a bit odd seeings as it's clearly built to go over anything - yet a speed hump is causing issues!!!
I don;t think it's the shocks themselves that cause this for me as I've done Pro Comps and now I'm on Rough Country.
The only thing is I expect they will change the distance the shock allows your axle to droop as one end of the shock has moved. This culd cause the springs to dislocate if you don't have the bottom of them clamped. They might be best bought with ORA rear spring clamps.
Rob B - what's your thoughts??? I imagine you have spent some time testing them???
Time to create page: 0.139 seconds
