King Pins and Bearings
- Thank you received: 115
13 Jul 2010 13:26 #3793
by maverick
Jalapeño, IISY?
King Pins and Bearings was created by maverick
I still have the horrid Jimny "death-wobble" and some grease is starting to ooze out of the N/S Front CV Housing so I've ordered new King Pin Bearing Kit from Martin ...
...and thought whilst it was all apart, I'd be best to see how the bearings are too?
Does it make sense to replace bearing and King Pin Bearings at same time? .. any are there any pit-falls to look out for?
Jalapeño, IISY?
13 Jul 2010 15:27 #3794
Replied by mlines on topic Re:King Pins and Bearings
If I knew the definitive answer to curing Death Wobble I would be a rich man.
You are starting in the right place, the Kingpin Bearings, particularly if there is "grease" leaking from the joint.
However chasing the wobble can be a long task. When the hubs are apart to change the Kingpin Bearings you will have access to the rear of the wheel bearings. Take a close look at the bearing race you can see from the rear. If it looks rusty then a change is best. Its a double race bearing and I have had one collapse on the inner race and not show any signs of problems because the outer race was still perfect.
Look at the track rod ends for wear and generally rock the steering back and forwards. Get the steering alignment checked. Mine wobbles with all new bearings etc. and when I took it to the garage they found it impossible to align front to rear. I am taking the axle off and looking at both the front leading arms and the panhard rod for possible issues. I know during my creation of the adjustable panhard rod that it is possible to create extreme wobble so this is a possible area of problems.
Good luck!
Good luck!
14 Jul 2010 08:03 #3795
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re:King Pins and Bearings
Hi Martin,
New Kingpin and Front Wheel Bearings arrived today...
Do you do OEM Trackrod ends?
Brett
Brett
Jalapeño, IISY?
14 Jul 2010 09:30 #3796
No I don't do them at the moment, mainly because they are so cheap from your average motor factor.
See here - www.eurocarparts.com/ecp/c/Suzuki_Jimny_.../Track-Rods-and-Ends
Delphi TA1996 and TA1997 are what you are looking for.
15 Jul 2010 06:46 #3813
by MigCooper
Snorkel and plenty of rust to be treated
Replied by MigCooper on topic Re:King Pins and Bearings
I solved my problem just by replacing the kingpin bearings
It still does a very suttle wobble from time to time, but it is realy sutttle and I can leave with that ....
- ooky_123
21 Jul 2010 11:40 #3926
by ooky_123
Replied by ooky_123 on topic Re:King Pins and Bearings
Since changing the brake disks and pads I have eliminated some of the wobble in ours. Im away at the moment but the wife has been complaining that the Wobble has "Moved" to a different speed.. before it was less noticeable and when you braked, the Jimny tried to exit stage left !!!
Now its a wobble.
Might have to get some Kingpin bearings too .. How difficult are they do do ?
Also changing the Hubs to manual ones
Now its a wobble.
Time to create page: 0.162 seconds
