Hot start issues - dieing battery
19 Apr 2012 07:55 - 19 Apr 2012 08:02 #37982 by facade
Clean up all the earths, and the battery connections, as said already.
It could just be a dodgy starter motor.
I'm sure someone had this problem on here before, but I can't remember what caused it, try a few forum searches.
EDIT www.bigjimny.com/index.php/forum/7-jimny...uki-jimny-1997#33115
Doesn't look like he fixed it though.
One other thing springs to mind:
When it does it again, try turning the engine over by hand to see if it is partially seized.
If they don't get regular oil & filter changes the cam seizes in the head.
Last edit: 19 Apr 2012 08:02 by facade.
The following user(s) said Thank You: goatboy
  • goatboy
  • Visitor
  • Visitor
19 Apr 2012 08:58 - 19 Apr 2012 09:00 #37989 by goatboy
Replied by goatboy on topic Re: Hot start issues - dieing battery
Cheers Facade.
I even posted on that guys thread, totally forgot about it! :laugh:
Gut feeling is a dodgy sensor that plays up once hot, but it doesn't seem to tie-in to the lazy turning over.
I'll give it a good look over at the weekend and see if I can see anything obvious.
Just to note the car is running fine other than this. I can't tell if its conking out or if its me stalling that triggers the problem. First time I was offroad and a tiny bit stuck so could have easily stalled, 2nd I was just trying to reverse into a parking space and could have easily stalled.
Last edit: 19 Apr 2012 09:00 by goatboy.
19 Apr 2012 09:11 #37990 by facade
The bit that worries me is you have a lazy starter, with a jump battery and no other change it spins fast.
This would tend to rule out poor connection/dodgy earths. The extra battery provides more current, to overcome a partially seized starter or engine. (or make up for a dead battery or an abnormal electrical load [ one big enough to stop the starter would be burning a wire up somewhere though])
But it is fine when cool, points more at a partial seizure from heat to me. A few people have seized a cam, the engine performance is down a lot and then it eventually grinds to a halt. Could be overheating generally but the gauge would show above normal.
I've not heard of a battery getting a poor connection inside when warm, but repairing itself when cold.
  • goatboy
  • Visitor
  • Visitor
19 Apr 2012 09:54 #37991 by goatboy
You are probably right, I'd be very suprised if it was the cam as the car is well looked after, but starter motor is quite probable.
Cheap things first though!
Time to create page: 0.383 seconds
