new suspension - recycling front springs ok?
  • darthloachie
  • Visitor
  • Visitor
18 Apr 2012 12:26 #37904 by darthloachie
Replied by darthloachie on topic Re: new suspension - recycling front springs ok?
dont forget +2" springs + 1.5" spacers will give you a 3.5" lift if you fit both and you might need castor correction bushes for the front radius arms
  • Black Toy
  • Visitor
  • Visitor
18 Apr 2012 12:41 - 18 Aug 2012 03:56 #37905 by Black Toy
Replied by Black Toy on topic Re: new suspension - recycling front springs ok?
Hi mate!
I'm going to remove the spring spacers. Just wondering if I should keep the rear shock repositioners (shock spacers)...
Last edit: 18 Aug 2012 03:56 by Black Toy.
  • supergaz
  • Visitor
  • Visitor
18 Apr 2012 16:21 #37910 by supergaz
Keep the rear shock repositioners as your bottom bushes wont last 5 minutes without them, Unless fitting rear castor correction arms.
  • Black Toy
  • Visitor
  • Visitor
18 Apr 2012 17:50 - 18 Aug 2012 03:27 #37918 by Black Toy
Thanks supergaz!
By bottom bushes you mean the rear shock bottom bushes, right? I've already replaced them to avoid adding washers to fill up the extra space with the new repositioners:
Last edit: 18 Aug 2012 03:27 by Black Toy.
  • bigoffroader
  • Visitor
  • Visitor
18 Apr 2012 17:54 #37919 by bigoffroader
Replied by bigoffroader on topic Re: new suspension - recycling front springs ok?
Yes you can use the front springs in the rear and they will give you a 2" lift meaning you only need to buy +2" front springs :)
  • supergaz
  • Visitor
  • Visitor
18 Apr 2012 19:02 - 18 Apr 2012 19:03 #37925 by supergaz
Black Toy wrote: Thanks supergaz!
My Jimny being "guarded":
If you lift (rotates the axle) the rear suspension it puts the rear lower shock bolts pointing down (diff up), so then the bush is always under pressure, the shock mount rotates the bust 90 degrees to take the strain out of the lower bush.
Last edit: 18 Apr 2012 19:03 by supergaz.
Time to create page: 0.149 seconds
