Iridium Spark Plugs
  • DVF
03 Aug 2010 21:37 - 04 Aug 2010 07:02 #4048 by DVF
Replied by DVF on topic Re:Iridium Spark Plugs
Standard plug for Jimny M13A (VVT)engine is NGK, LFR6J-11. They're not uncommon and any parts shop or factors should have them. Parts suppliers reference books only show G13B engines for Jimny's from what I've seen.
EDIT: IFR6J-11, not LFR
Last edit: 04 Aug 2010 07:02 by DVF.
  • P.Y.
04 Aug 2010 05:09 #4049 by P.Y.
Replied by P.Y. on topic Re:Iridium Spark Plugs
Is this the one referred to earlier that is called the "R" with a little V cut in the electrode, that runs cooler than an Irridium? What is the reference number for a 2005 Jimny twin cam (dont think its the VVT this old) for this plug, and, also Irridium alternative, please, as I need to get both (its for the London to Cape Town rally entry). thanks. py
04 Aug 2010 05:39 - 04 Aug 2010 05:42 #4050 by facade
Replied by facade on topic Re:Iridium Spark Plugs
According to the manual
Spark plug type
NGK : BKR6E-11, IFR5E11
DENSO : K20PR-U11, SK16PR-A11
Sparkplugs.co.uk recommend
Denso irridium IK20 £7.23+vat
Denso irridium tough VK20Y £10.98+vat
or NGK irridium IFR5E11 £13.20 +vat
the NGK BKR6E-11 is £2.30 + vat
and the Denso K20PR-U11 is £1.98 + vat
Last edit: 04 Aug 2010 05:42 by facade.
  • DVF
04 Aug 2010 07:13 - 04 Aug 2010 07:17 #4052 by DVF
I think you'll need to get under your bonnet to find out what engine you've got and what spark plugs it uses. Take one of the spark plugs out and get the code off it. It probably does have the VVT engine if it's a 2005 which means the iridium spark plugs are standard fit, but you'll need to check under the bonnet to find out.
Out of curiosity, why do you need two types of spark plug for the rally? EDIT: Ah, right, for the poor quality fuel you'll get on the way down there.
Last edit: 04 Aug 2010 07:17 by DVF.
  • P.Y.
04 Aug 2010 14:25 - 04 Aug 2010 14:28 #4056 by P.Y.
Correct! The cars leave Parliament Square in the evening of New Years Eve and drive two tests in woods in Kent, and an hour of tightly-timed lanes on the North Downs before Dover, and in Northern France there is a timed section down a hopefully not too muddy track called The Somme Time Trial, and after all this, some results will be chalked up. Look out for the Jimny as it could be putting up a surprising result at this point (ok, Cape Town is still a long way off, but its the twisty bits that will suit it best, and the two drivers have both won rallies in the past in the 1400cc-Endurance Rally scene).
They want to run the best possible early on, so, the best fuel available, and to take advantage of that it makes sense to run Irridium plugs. Before crossing to Africa, somewhere in the south of France, they will stop and change plugs no doubt, if the running of a cooler plug suits a lower grade of fuel.
2005 engine - didnt think it was VVT till later. How can we spot the difference.
Thanks for your advice.
Last edit: 04 Aug 2010 14:28 by P.Y..
Time to create page: 0.242 seconds
