interior light
  • BIG-P
23 Mar 2012 19:43 #36237 by BIG-P
interior light was created by BIG-P
Hi folks.
Is there a fuse for the interior light?
It isn't working,i've put a multimeter across the bulb and I have continuity so wondering which fuse to replace as I don't have a handbook.
Thanks in advance :)
  • adamjimny
23 Mar 2012 21:16 #36251 by adamjimny
Replied by adamjimny on topic Re: interior light
There is a fuse yes but i cant remember which one off top of my head but im doin more on mine tomoz afternoon so if no one replys ill let you know with piccies pal
Sent from my GT-I9100 using Tapatalk
24 Mar 2012 07:28 - 24 Mar 2012 07:33 #36262 by facade
Replied by facade on topic Re: interior light
I thought the fuse box lid had the fuse functions on?
You want the middle fuse labelled "dome", (dome is foreign for interior light)
Anyway, test with your multimeter, stab the probes to both ends of the fuse through the little holes provided. If you get 12V the fuse is gone. (when the thing it protects should be on)
You can get expensive fuse testers that have a light that does the same thing.
BTW the interior light can be switched off at the light, 3 positions: on all the time, off all the time, and auto
BTW2 the fuse box is the one in the footwell, not the one under the bonnet.
Last edit: 24 Mar 2012 07:33 by facade.
The following user(s) said Thank You: BIG-P
  • BIG-P
24 Mar 2012 15:53 #36280 by BIG-P
Replied by BIG-P on topic Re: interior light
Gutted,fuse is fine,bulb is fine.
Looks like an annoying one ,cheers folks.
24 Mar 2012 16:53 #36289 by facade
Will it come on with the switch on the light itself?
There is very little to go wrong.
One side of the bulb is permanent live- white wire from the dome fuse.
The other side of the bulb gets earthed out either by the door switches- black & red wire, or the switch inside the lamp - black wire.
page 8A-7-33 in the wiring manual.
  • BIG-P
24 Mar 2012 19:14 #36301 by BIG-P
facade wrote: Will it come on with the switch on the light itself?
Hi,no it won't come on at all,switches on all positions,very strange .:angry:
