over heating at 50+
  • oldsilver
09 Jun 2010 19:50 #3592 by oldsilver
over heating at 50+ was created by oldsilver
Still over heating if driving above 50 miles an hour, not loosing water or when standing in traffic its fine, could it be head gaskit,? no water in oil or visa versa
Does any one know how to check wether it is the fan or the switch?
10 Jun 2010 05:53 #3597 by mlines
Replied by mlines on topic Re:over heating at 50+
You don't say how old your Jimny is.
The old ones have a Viscous fan whilst the recent ones have an electric fan. I would guess that its the Viscous Fan one.
The Viscous oil gets tired or even leaks out over time meaning that the fan slips at high revs. If you can get hold of some cable ties it is possble to "lock" the outer part of the fan to the hub forcing the fan to turn all the time. This will increase the noise of the engine and affect economy at low revs but will tell you if the problem is the fan. Its pretty fiddly to get the ties in place.
The other test is to get it hot and then try stopping the fan with a rolled up newspaper. This is quite dangerous and exciting to do but if the fan can be stopped then the Viscous mechanism is broken.
Its not possible to fix the mechanism. I took mine apart and the oil escaped quicker than MP's when someone shouts "Whos expenses claim form is this?". I simply rebuilt the mechanism with a piece of cardboard jammed inside to stop it slipping and all my cooling issues went away.
martin
  • oldsilver
10 Jun 2010 10:41 #3604 by oldsilver
Replied by oldsilver on topic Re:over heating at 50+
Thanks Martin,
I will try that this afternoon, I will let you know
how I get on later.I will try and get some photos on later as well
because I want to strip the bumpers off to make up some winch bumpers up but wanted to get the running stuff fixed first.
Ade.
  • Knight.
15 Jul 2010 11:39 #3831 by Knight.
Replied by Knight. on topic Re:over heating at 50+
oldsilver wrote:
Thanks Martin,
Ade.
Did you fix this in the end?
  • oldsilver
27 Sep 2010 17:31 #4853 by oldsilver
It was the viscous fan I think that started the problem, Its caught me out a couple of times bioling over, now I have to change the head gasket. Water in the oil!.Don't let it get too hotlike I did.
  • andyw
27 Sep 2010 18:36 #4859 by andyw
Replied by andyw on topic Re:over heating at 50+
Hi,
Hows the rad, clean or full of crud ( Fins ), :) sounds like you've still the plastic on, not rad related but the front cross member can get full of mud :ohmy:
Andy
Time to create page: 0.275 seconds
