Just bought a Jimny and need a bit of advice...
- Thank you received: 652
02 Jun 2010 19:42 #3527
by facade
Just bought a Jimny and need a bit of advice... was created by facade
Hi everybody
Just bought a Dec 2000 estate (needed before March 2001 for the cheap tax) previously I ran LandRovers :blush:
I have a couple of problems
1) the air pipes over the axle don't seem secured properly, they are secure, but there are several attachment tabs with a hole in that are in fresh air, and a couple of pipe keeper togethers that don't as it looks like the pipes are on backwards.
Is this right? is there a drawing/photo of a front axle anywhere showing the routing of the pipes?
2) When I drove it, all was fine except, when I pull away, usually when turning out of a junction, and shift into second, there is a vibration from the rear until the revs pick up.
It only does it at low revs, and only in second. I tried to get the chain to jump, as suggested on here before I bought it and it doesn't.
Feels a little as if there is a limited slip diff at the rear snatching.
This could be me, I do tend to use 1st to just get the wheels rolling and then shift up ASAP. Tomorrow I will check out the UJs and try reving a bit higher in 1st before I change to 2nd, in case it is simply some strange driveline harmonic.
03 Jun 2010 05:25 #3529
Replied by mlines on topic Re:Just bought a Jimny and need a bit of advice...
Hi,
The air pipes on mine are also very bent and do not look secured properly, I think this is pretty much how they are. There is a diagram in the manual but to be honest its such a poor quality that its not worth reproducing here.
On your second problem I would have looked first at the Transfer box chain and then at clutch judder.
03 Jun 2010 06:49 #3530
by facade
Replied by facade on topic Re:Just bought a Jimny and need a bit of advice...
thanks for the reply.
There aren't any fixings on the axle where the tabs on the pipes are, but they seem secured at the back.
I checked here before I bought it, and you suggested trying to jump the chain off by dropping the clutch in low, and it doesn't jump.
(as an aside, it cost me £90 to sort out the chain jumping on my mountain 'bike, full set of sprockets and a new chain, so I know how to get a drive chain to jump :lol: )
I searched the forum, and in the past a couple of people have described it as a "BRRR in second" but don't seem to have offered a solution. Seems more of a vibration to me. I'll check it out today, just got a little fettling to do round the rusty bits :ohmy:
One other thing, the swivel housing balls are as rusty as old iron. Is this right? I'm used to replaceable chromed balls that are full of ep90, I know a suzuki is dry inside. Should I clean them up and paint them?
03 Jun 2010 07:20 #3531
Yes, its probably worth cleaning them up and putting paint on them. You will find that MOT test people get a fixation on what they remember from Landrovers (They need clean shiny chrome with no oil leaks to pass. Jimnys look similar but aren't, therefore you may fail on rust and pitting on the steel surface which is in fact not relevant in the same way as it was on Landrovers. Therefore keeping them painted will help
03 Jun 2010 16:37 #3536
by Garry
Replied by Garry on topic Re:Just bought a Jimny and need a bit of advice...
my jimny vibrates to, its just low revs on mine tho, i do the same, 1st to get going then into 2nd.
- JonathonMarshall
- Premium Member
- Thank you received: 2
04 Jun 2010 05:02 #3540
by JonathonMarshall
Replied by JonathonMarshall on topic Re:Just bought a Jimny and need a bit of advice...
yeah that'd be me with the brrr in 2nd. Its still present and I'm still at a loss. UJ's were suggested but i've had a feel and they feel ok?. Its a very annoying symptom...i do find that slipping the clutch stops it though so it could well be clutch judder. It shakes the bones of the car though!!
Time to create page: 0.240 seconds
