Just done my first wheel bearing
- kevant
21 May 2010 22:01 #3436
by kevant
Just done my first wheel bearing was created by kevant
just done my first wheel bearing on my jimny tonight and all hail to the mighty how to guides on this site only thing we really had trouble with was getting the old bearing out of the hub but after 15 mins with the blow torch and a load of hammering we finally sorted it and it would be really nice to find a bearing tool from somewhere if anyone has any ideas as we had to use and hammer and flat punch to get the retainer ring off as with having manual hubs on i am not too bothered about the seal for the vac side of things. Also found a local dealer who supplied the full bearing fit for just under £45 so happy days and i am defo going to get a spare for the other side.
22 May 2010 17:53 #3440
by Foxtrot
Replied by Foxtrot on topic Re:Just done my first wheel bearing
Hi Kevant, well done with the wheel bearing. I've just been under my 2006 Jimny and the passenger side kingpin is oozing grease. Looks like it is goosed, I'm hoping the extended warranty will fix it. Was it straight forward to do?
- kevant
22 May 2010 20:07 #3441
by kevant
Replied by kevant on topic Re:Just done my first wheel bearing
Not too bad thanks to Martins How to guide my advice is to print out the guide and leave it in the car for when you start the job also make sure you have a couple of decent axle stands as the cheaper ones dont instill any confidence when working on the car with a wheel off. Another thing which i found was getting the circlip off the driveshaft was quite a chore so make sure you have a good set of circlip pliers otherwise you will possibly break the clip like i did which means if you havnt been supplied any in the kit your screwed and if you do end up doing it yourself you might consider checking out the bearing at the same time lets hope you can get it done on warranty otherwise read the guide get you car on the drive and get a mate to help 2 heads are alawys better than one
Time to create page: 0.149 seconds
