shock absorber brackets
  • bryandenham
10 May 2010 15:35 #3367 by bryandenham
shock absorber brackets was created by bryandenham
Hi, what stops the lower part of the extension bracket from rotating when the axle has one wheel lower or higher than the other? Is it just the face contact and the tightness of the bolt or if not , what stops the bolt from coming loose?
cheers, Bry D
10 May 2010 17:10 #3368 by funkyjimny
Studlock on the threads of the bolts ! losing those bolts is a common jimny problem in standard or modified form!
Gary
  • bryandenham
10 May 2010 17:39 #3369 by bryandenham
Replied by bryandenham on topic Re:shock absorber brackets
cheers! BUT i actually meant the adaptor rotating on the pin, not the pin itself rotating.
thanks anyway. BryD
10 May 2010 17:41 #3370 by funkyjimny
I have mine fitted with washers either side, but tbh its still fairly solid. The shocker is in a much better poition with the brackets fitted than when it was before, and theres enough movement on the bush to articulate.
Gary
  • bryandenham
10 May 2010 17:53 #3371 by bryandenham
thanks gary, i'll give it a whirl and see how it goes. There are a lot of them around so it should be ok. if necessary i'll weld them on or completely fabricate a complete mount.
BryD
  • Garry
10 May 2010 18:16 #3372 by Garry
Replied by Garry on topic Re:shock absorber brackets
i wouldnt weld them on, i may be wrong, but i think the move a little when the shock moves,
on a different note, i had them fitted then took them off again, my 2 rear shocks got burst seals with them on, my fault tho, its still on standard supension.
Time to create page: 0.162 seconds
