PSD of 2005 jimny
  • blakey2000
08 Feb 2012 00:21 #32988 by blakey2000
PSD of 2005 jimny was created by blakey2000
Just seeing if anyone knows the PSD (Wheel Stud Pattern) for a 2005 jimny.
iv looked everywhere for it but no luck at all to finding it.
  • ZookFastback
08 Feb 2012 04:30 #32989 by ZookFastback
Replied by ZookFastback on topic Re: PSD of 2005 jimny
The Jimny rim is... 5/139.7, centre hole diameter 110mm. The actual hub diameter is... 108.4 Offset is... 5
Would you like a comprehensive list of compatible makes rims?
  • ZookFastback
08 Feb 2012 04:45 #32990 by ZookFastback
This is a list of compatible wheels for the Lada which has the same stud pattern 5/139.7 as the Jimny. Bear in mind that the Jimny centre needs to be 110mm, the Lada centre varies from a minimum of 98mm.
www.ladaniva.co.uk/baxter/resources/StudPatternList.htm
Time to create page: 0.157 seconds
