coolant bottle full..radiator low
08 Feb 2012 12:51 - 08 Feb 2012 12:52 #33014
by facade
Replied by facade on topic Re: coolant bottle full..radiator low
It isn't a pressure test you need, but a test for combustion gas in the water.
What happens is the head has a slight warp, and a teeny teeny bit of gas is leaking from a cylinder into the water, due to the very high pressure. A pressure tester from the radiator end will not force water the other way, so it will pass.
Over time this blows the water into the expansion bottle, and when everything cools, leaves air in the top of the radiator.
If you let it cool overnight, and crack the rad cap open, if you hear a little hiss of air escaping the head gasket needs doing, and most likely a slight skim off the head to correct the warpage.
Last edit: 08 Feb 2012 12:52 by facade.
- bluejimny
08 Feb 2012 15:09 #33027
by bluejimny
Replied by bluejimny on topic Re: coolant bottle full..radiator low
as above, thats what happened to mine!!
- 247sniper
08 Feb 2012 17:18 #33044
by 247sniper
Replied by 247sniper on topic coolant bottle full..radiator low
It's a cylinder leakage test you need. That's the only way to be 100% sure.
Steve.
Steve.
