Help fitting new horn, please
  • Frog
28 Jan 2012 15:40 - 28 Jan 2012 15:41 #32046 by Frog
Help fitting new horn, please was created by Frog
I have fitted a new horn physically, but am now stumped by the wiring.
There appear to be two 12V+ wires going to the OE horn, with the 12V- being supplied by the fixing bolt. Can anyone enlighten me. Also, do I need to fit another relay and/or uprate the fuse, or will the OE bits do? The new horn is just a dual tone one, so nothing too heavy for the wiring...
Last edit: 28 Jan 2012 15:41 by Frog.
  • VAXXi
28 Jan 2012 15:58 - 28 Jan 2012 16:01 #32049 by VAXXi
Replied by VAXXi on topic Re: Help fitting new horn, please
The Jimny's electricals are ground switched, meaning you have a permanent +12V and the ground wire (negative) is connected when needed. So that's why you have two wires: one is permanently live, the other one goes to ground but it's only connected when you press the horn button. The car body is indeed a ground point also, but it's permanent; cannot have the horn sounding constantly :)
The default horn is rated at 4A (it's a motorcycle horn, actually, not kidding); most of the "real car" horns are using more than that. I've also replaced my horn and the new one said it draws about 12A, so I've replaced the original horn with a relay and supplied power directly from the battery.
Old setup:
--livewire----> (horn) <
grounding_wire----
New setup:
--livewire----> (relay pins 85,86) <
grounding_wire----
----fused_wire_from_battery----> (relay pins 30,87A) <
wire_to_horn----> (horn) <---grounding_wire----
When you push the horn button, the relay closes and supplies power to the horn. No mods to the original car wiring, easy to switch back if desired, can reposition horn if desired (I've put mine behind the headlamp, as it was quite exposed in the original position and the new one didn't fit there anyway).
Last edit: 28 Jan 2012 16:01 by VAXXi.
  • Frog
29 Jan 2012 08:34 - 29 Jan 2012 08:35 #32093 by Frog
Replied by Frog on topic Re: Help fitting new horn, please
Many thanks, that's really helpful information. I have owned about 25 cars in my time, but negative switched electrics is a new one on me :)
...as is a motorbike horn on a car - that explains why it's so weedy!
Last edit: 29 Jan 2012 08:35 by Frog.
  • VAXXi
29 Jan 2012 09:31 #32098 by VAXXi
Welcome! Yes, the stock horn is quite feeble and that's probably the reason for mounting it so "open" behind the grill: to be heard ! when I took mine out it was already beginning to corrode.
The negative switched wiring was a surprise for me also, but after thinking a bit it's quite clever actually: it's much easier to find and connect a grounding point when needed rather than pull a wire each time for bringing +12V to your gadget. Clever clever.
30 Jan 2012 16:57 #32219 by Johnniehec
VAXXi wrote: Welcome! Yes, the stock horn is quite feeble and that's probably the reason for mounting it so "open" behind the grill: to be heard ! when I took mine out it was already beginning to corrode.
Earth switched horn is quite common in fact I think it's pretty much standard. I think the reason might be the centre of the steering wheel button, much easier to switch an earth (just make contact with the steering column) than have a live wire there all the time as it'd be more likely to get broken or short out, there again maybe I'm speaking Bo*****s again!!
John.
  • rayz_x
16 Jun 2013 20:03 #74031 by rayz_x
Replied by rayz_x on topic Help fitting new horn, please
Have had my Jimny - 57 plate - two weeks now and have just replaced the parpy horn. I am not sure whether the standard wiring has changed but there wasn't a live feed to the horn. I disconnected the two wires to the horn and testing with a lamp the white wire was live when horn button was pressed. Black wire I guess goes to earth.
Fitted a relay where the old horn came out and connections as follows...
86 - white wire leading to horn button (disconnected from old horn)
85 - Black wire from old horn
30 - Live - took a feed direct from the battery with a 15A inline fuse holder
87 - to new horns - mounted on chassis behind bumper
One thing I did need to do was put an earth from the new horns to the body. The chassis didn't provide a good earth connection, I guess due to being separated from the body by rubber bumpers.
Ray
Time to create page: 2.776 seconds
