low gears for t/box
- miksyellowsj
25 Jan 2012 06:57 #31821
by miksyellowsj
low gears for t/box was created by miksyellowsj
im going to fit low gears or a rocklobsterbox but first, i have the box allready and just want to know on the gears ive seen forsale from jimnybits, what do the produce from the wheels are they the same as a lobster as i would rather fit them in the jimny box pros and cons please
thanks mik
thanks mik
25 Jan 2012 07:10 #31822
Replied by mlines on topic Re: low gears for t/box
Pro's:
(a) You dont have to get a mounting kit and speedo adaptor, just drop them into your t-box
(b) Cost effective because of (a).
Con's:
(a) They are 2.65:1 compared to 4:1 for a RockLobster, I had a similar set on my Jimny and it was not low enough for me.
(b) Relies on the existing Chain Drive.
Con's:
- reaper
25 Jan 2012 13:02 #31835
by reaper
Replied by reaper on topic Re: low gears for t/box
just out of interest can someone list ratios in order ie. stock ,low gear conversion , mini lobster,roxkkobster
thanks
thanks
- Johnniehec
- Thank you received: 56
25 Jan 2012 14:58 - 25 Jan 2012 14:59 #31839
by Johnniehec
Yes that would be good could someone complete a table with high ratio as well and stick it somewhere handy? No rude suggestions thanks!!
_________________________ Low _______________ High
Jimny Manual Mechanical
Jimny Manual Electric
Jimny Auto
410
413
Lobster 1
Lobster 2
Lobster 3
Replied by Johnniehec on topic Re: low gears for t/box
reaper wrote: just out of interest can someone list ratios in order ie. stock ,low gear conversion , mini lobster,roxkkobster
thanks
Jimny Auto
410
413
Lobster 1
Lobster 2
Lobster 3
Last edit: 25 Jan 2012 14:59 by Johnniehec.
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
25 Jan 2012 15:50 - 25 Jan 2012 16:18 #31841
by funkyjimny
Replied by funkyjimny on topic Re: low gears for t/box
Martin may be able to fill you in on some of the stock stuff, these are the ratios for the SJ rocklobster boxes made by Rob Storr. I have a 6:1 in mine with near 32" tyres (750.16's) and find the on road gearing a little undergeared but off road its amazing, it'll climb near anything given the traction - hard work going anywhere in reverse in low box though !. 4:1 is the most popular ratio, I had a Rob Storr one in my first jimny and it was fantastic with 215/80/15 tyres which were about 29".
the 'cut and welded' boxes that some make at home are 4:1 ratio I believe.
4:1 Works great with tyres up to 30†12% High - 83% Low £375.00
5:1 Well suited for 31†& 32†21% High - 128% Low £475.00
6:1 The only great gear set designed for 33†24% High - 170% Low £525.00
8:1 King of the rocks, makes you lower than a
Snakes belly 24% High - 260% Low £625.00
taken from www.rsmfg.co.uk
Gary
Gary
Last edit: 25 Jan 2012 16:18 by funkyjimny. Reason: typo
- gabitzu
25 Jan 2012 17:03 #31847
by gabitzu
Replied by gabitzu on topic Re: low gears for t/box
jimny electric, manual transmission
1.001 high, 2.002 low
jimny electric, auto transmission
1.32 high, 2.643 low
see above, the electrical t-case has the reduction 1;2, manual or auto. the manual t-case has 1;1.5
jimny manual, manual transmisssion
1.32 high, 2.145 low
jimny manual, auto transmission
i don't know :S
a samurai of my friend, but don't know if it's samurai or sj413 really,year is 92-93 manual transmission
1.409 high, 2.268 low
also, i think it's not so helpful to post percentages or gear reduction without mentioning what is the original :laugh:
i don't know :S
Time to create page: 0.406 seconds
