half shaft
- suzuki jimny fella
20 Jan 2012 19:40 #31435
by suzuki jimny fella
half shaft was created by suzuki jimny fella
has eny one had a rear half shaft fall out my mate said his has got to go have a look tomorrow
- Bigchridy
20 Jan 2012 19:56 #31438
by Bigchridy
Replied by Bigchridy on topic Re: half shaft
Had mine out last weekend to change the wheel bearings. They are held in by the drum back plate which bolts to the axle. Technically they shouldnt be able to fall out. Unless maybe a bearing has collapsed. If he has a rear disc conversion fitted they have a retaining plate which again bolts to the axle.
Hope this helps
Chris
Hope this helps
Chris
- mcjimny
20 Jan 2012 20:46 #31441
by mcjimny
Replied by mcjimny on topic Re: half shaft
As above, they "technically" shouldn't come out. When fitting them you tap(translate to belt/whack) them back in then the back plate bolts on to secure it. After refitting and a few miles i check the nuts. Or again as above the bearing has collapsed
If those nuts were loose or something then with normal driving the shaft could come out of the recess where the bearing sits.
20 Jan 2012 20:59 #31443
Replied by mlines on topic Re: half shaft
If the rear wheel bearing collapses the entire shaft and wheel can part company from the car.
Sent from my HP Touch pad running Android ICS using Tapatalk
- jimny5
20 Jan 2012 22:56 #31451
by jimny5
Replied by jimny5 on topic Re: half shaft
My mates fell out of his sj. Full wheel, hub and shaft, the 4 bolts for rear disc conversion snapped.
21 Jan 2012 17:57 #31500
by kirkynut
Replied by kirkynut on topic Re: half shaft
I have been told, although I'm unsure how much I believe it, that if you drive on ruts so that your wheels are continuously being pulled apart for some time, the forces on the bearing and retainer are such that the wheel pushing out can pull the bearing and retainer off the shoulder on the shaft that they are pressed onto.
That would have the same effect.
I watched an episode of the American Top Gear yesterday - rubbish - but nonetheless, they had a Ford Bronco on there which had the same issue. I'm not sure of what the rear bearing set up is on one of those but it must be similar for it to have occurred the way it did.
