Lock right 1510
- Snize
20 Jan 2012 16:54 #31423
by Snize
Lock right 1510 was created by Snize
I want to install my gimny lock right 1510,I want to do it myself ,I want to know what the risks ? Is there any guide book ?
- Bigchridy
20 Jan 2012 19:42 #31436
by Bigchridy
Replied by Bigchridy on topic Re: Lock right 1510
- supergaz
20 Jan 2012 19:50 #31437
by supergaz
Replied by supergaz on topic Re: Lock right 1510
Hi and welcome to the forum.
Don't undo the side bearing lock plate as is done in the guide, as then you will loose the side bearing adjustment. Just undo the 2 big bolts for the bearing caps.
21 Jan 2012 12:27 #31479
by zerez
Replied by zerez on topic Re: Lock right 1510
Hi,
I have a general qustion.
I am using my 2006 jimny for off and on road driving. My jimny has an automatic transmition an have the maxxis 751 tieres.
What is the impact of using the 1510 on roads?
- Romi
10 May 2012 09:40 #39813
by Romi
Replied by Romi on topic Re: Lock right 1510
Hi ,
I have installed 1510 to 2006 Jimny. But the problem is dif. lock is very tight and did not release while parking moves and slow cornering.
We have removed all slug but it is still same; could you advice how we would instal lock right 1510 to work properly?
Thanks,
Oktay
Thanks,
Oktay
- supergaz
10 May 2012 15:01 #39839
by supergaz
Did you use the shim washers supplied? Or doubled up on the shims?
I think you have it shimmed to tight so that it cannot unlock.
I only used to originals and I can spin my wheels by hand and can hear a ratcheting click.
