removing back seats and seat belts
  • little jimny
09 Jan 2012 16:52 - 09 Jan 2012 17:03 #30384 by little jimny
removing back seats and seat belts was created by little jimny
My dogs keep getting caught up in the back seatbelts, so I want to remove them. Obviously this will cause a problem come MOT time if the back seats are still in, so I'm going to remove them as well. Can anyone offer any tips on how to do this, in particular it looks like I'll have to remove the side trim to get at the bottom seat belt mounting but I can't quite figure out how it comes out.
Last edit: 09 Jan 2012 17:03 by little jimny.
09 Jan 2012 17:03 - 09 Jan 2012 17:07 #30387 by Johnniehec
Little jimny, no it's the other way round you've got to take the seats out to get the side panels off. side panels are a pain in the A**e to take off. Just take the seats out, there are bolts in the actual seat back pad rather than unbolting the bracket from the side panels if I remember correctly then you can get at the seatbelts. The ones in the centre are bolted down throught the floor, the plastic trim is also a b****r to get off and they're bound to be rusty.
John.
I knew I'd seen a photo, it's the nut on the LHS of this picture you're after.
Attachment Photo0220.jpg not found
Last edit: 09 Jan 2012 17:07 by Johnniehec. Reason: Add photo
The following user(s) said Thank You: little jimny
09 Jan 2012 18:22 #30393 by Halford
  • little jimny
09 Jan 2012 18:47 #30396 by little jimny
Replied by little jimny on topic Re: removing back seats and seat belts
Thanks guys - looks like it'll be more than a ten minute job then!
  • little jimny
11 Jan 2012 21:21 #30698 by little jimny
Job done B)
As suggested, some of the bolts had gone a tad rusty and took a fair bit of effort to remove. I also needed to remove the rear trim that runs under the door to release the side trims where they tuck under. When I did the second side I only pulled the side trim clear at the back - that gave me enough clearance to remove the seat belt without the hassle of removing the whole trim at the front. Lining the side trim back up to put it back on was a PITA too!
  • GuardianAngel
20 Sep 2012 17:02 #48427 by GuardianAngel
Replied by GuardianAngel on topic Re: removing back seats and seat belts
Sorry to bring up an old post, but would removing the back seats have a negative impact on insurance?
I am thinking that I wont be carrying passengers so less likely to have PI claims if I had a prang.
Sent from my GT-I9100 using Tapatalk 2
Time to create page: 0.240 seconds
